Anyone else drive aggressively? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 11-06-2011, 10:46 PM   #1 (permalink)
Default Anyone else drive aggressively?
Trying to figure out if this is just something the car does, or is an issue.
I'm trusting that the gearbox in the CR-Z is solid, it's a Honda, and built extremely well - I have no reason not to believe it wouldn't withstand quite a bit.
That being said, when merging onto a highway, I'm typically running 4th gear up the ramp at around 55-60mph. Usually hovering around 4,500rpm.
From that point, if I'm in the clear, I will typically apply WOT, in which I have noticed the car pull RPMs up to like 5-5.5k, but lose rpm.
Is this a green feature, because the electric motor is on full blast?
Or is my car potentially losing copious amounts of back pressure, thus losing throttle?
Curious if anyone else drives as... aggressively as I.
Widget is offline   Reply With Quote
Old 11-06-2011, 10:55 PM   #2 (permalink)
sohcsol's Avatar
Try to be a little more descriptive...
1) Are you in eco mode when this happens? If so have you tried it, say, in sport mode instead?
2) If the car is pulling from 5k to 5.5k rpm, aka increasing rpms, how is it also losing rpms? This was a very unclear statement. The redline is just over 6k i believe, and I usually shift by then but havent noticed anything unusual.
Its also possible your battery is down to 3 bars where it stops using IMA assist. Check your battery meter when this happens.
2011 CR-Z EX, 6MT, CBP, #7960
Old 11-07-2011, 02:41 AM   #3 (permalink)
varg's Avatar
Only reason I can see it losing rpms would be VSA. Try it in sport mode with VSA off. When I track the car or even just in sports mode I turn it off. My rutine for switching to sports is actually pressing the VSA button at the same time.
varg is online now   Reply With Quote
Old 11-07-2011, 09:33 AM   #4 (permalink)
1. No, definitely in Sport mode when driving aggressively.
2. Will be hovering about 4-4.5k RPM, apply WOT, then it will lose RPMs after a quick second of WOT at around 5.5k, which will drop it back down maybe to 4.5-5k RPMs. I'm not sure how it's losing RPMs, that's why I posed the question here - I know it's losing RPM because the tachometer clearly shows the car draining RPMs.
Battery is usually fine - during this whole time, the IMA is on full blast... as I stated in my original post.
Thanks for the feedback! I may have to try this and see if it alleviates the issue. However, I currently don't feel too comfortable during off the VSA with the stock tires (oh my god, they are awful), plus that orange light is god awfully annoying.
Any tips on getting over that orange light there, mate?
Old 11-07-2011, 09:51 AM   #5 (permalink)
majestic's Avatar
my guess too would be VSA kicking in, but i go WOT a lot and never experience VSA. its not like our cars would have enough power to make the tires lose traction at 4.5k in 4th gear.
how many miles do you have on your car already? could it be your clutch slipping already?
CBP 6spd EX
majestic is offline   Reply With Quote
Old 11-07-2011, 09:56 AM   #6 (permalink)
varg's Avatar
If you aren't comfortable turning VSA off, just watch for the light flashing when you get the rpm drop. Most likely it is trying to correct wheel spin or wheel slip due to understeer/oversteer.
...and yes, the stock tires are HORRIBLE. I still have them in my garage. I tried to give them away on FB, but noone wants them!
Old 11-07-2011, 10:02 AM   #7 (permalink)
I doubt vsa is kicking in @ 50mph in 4th gear unless you are taking a turn, if you're acceling up an onramp. Some more clarification would be good is this a 6mt or are you in a CVT with the "manual" mode turned on?
Old 11-07-2011, 10:07 AM   #8 (permalink)
It's at 5,100 miles.
Also, I forgot to mention - I'm running CVT, using the tapshift controls - so I don't think it's the clutch.
Sorry, that was an important detail I left out.
Old 11-07-2011, 10:17 AM   #9 (permalink)
Heard of something similar with automatic transmissions: it was torque convertor lockup. I dont know how CVT's work so I cant say thats whats happening. I have never had this happen in my 6MT
Old 11-07-2011, 10:30 AM   #10 (permalink)
gordonfc's Avatar
No torque convertor in CRZ
