CR-Z has no alternator, is that right ? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 13Likes
post #1 of 25 (permalink) Old 04-06-2017, 06:37 AM Thread Starter
Hi,
Not sure if I have this correct.
But from what I read, the CRZ does not use an alternator to topup and supply 12v to the car.
Instead the IMA battery has a DC-DC converter for this.
Is that correct ? - I was just wondering what would happen if the IMA battery is empty, like after a long hill crawl with foot down.
So maybe this is not correct.
Thanks,
Keith
keithjmason is offline
post #2 of 25 (permalink) Old 04-06-2017, 06:56 AM
There is no alternator in a conventional sense. The IMA motor charges both the IMA battery and the under hood battery. It also provides the Motor assist when needed. It acts as both a "generator" and a motor. We also have regenerative braking which is another "power" source.
The CR-Z is very smart in how it manages energy and it moves it where it is needed. If there is extra it charges if you need more power to move the vehicle it uses the IMA as a motor. Just cruising along it uses it as a Generator.
I hope this long winded explanation helps your understanding. Others will be more eloquent in their responses.
This is why the under hood battery should be load tested( with the car not running) if you see any electrical oddities because the car prioritizes movement and IMA over the under hood battery charging. Once the car is running most things are using the IMA battery.
Defiant and Aceryl like this.
Last edited by Spdbump; 04-06-2017 at 07:02 AM. Reason: added load testing recommendation
post #3 of 25 (permalink) Old 04-06-2017, 08:43 AM
You'll never run the IMA battery down to nothing- the onboard controls won't let it happen. I'm always surprised when driving up 8000 feet up to Tahoe, under throttle, and the battery gauges showing the IMA is still "Charging". If your amount of throttle is such that the gasoline can maintain your requested power output, the system won't go to "Assist". But this happens without my trying to make it.
Your best bet with the battery indicators is to ignore them. There's nothing going on there for you to be concerned about, as the man behind the curtain is well in control. If you manage to load the system up enough to show the IMA battery "drained", it isn't true.
And yes, the Z has no separate alternator.
post #4 of 25 (permalink) Old 04-06-2017, 02:51 PM
rayray's Avatar
the closest thing to an alternator would be the IMA motor as stated by spdbump.
in technical terms it's a stator like those commonly found on motorcycles.
the recovered energy from the flywheel/crank assembly is what acts as the "alternator" in our cars.
'13 CRZ - PWP EX 6MT
mksengineering.com
rayray is offline
post #5 of 25 (permalink) Old 04-09-2017, 05:27 PM Thread Starter
Thanks everyone. That makes sense.
Cheers,
Keith.
post #6 of 25 (permalink) Old 04-09-2017, 05:28 PM
Cheers,
Keith.
You are very welcome now get off the forum and go drive!
post #7 of 25 (permalink) Old 04-14-2017, 10:14 PM
Hi,
Thanks,
Keith
An alternator is not required on an hybrid.
A typical alternator has a poor effciency of only about 55%.
The DC-DC converter that replaces it is probably around 90% efficient and much lighter than an alternator.
It's the same thing on the Insight.
I have not check other hybrids but I supposed it's the same.
Serge
litz and Defiant like this.
Serge is offline
post #8 of 25 (permalink) Old 04-15-2017, 12:27 AM
@ the speed of white
post #9 of 25 (permalink) Old 04-15-2017, 08:27 AM
Originally Posted by litz View Post
Video unavailable
post #10 of 25 (permalink) Old 04-15-2017, 09:22 AM
Video unavailable
Oh, but it was a good video too--I'll see if I can find it again.
