IMA Battery behaviour - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
 18Likes
post #1 of 22 (permalink) Old 02-27-2017, 07:19 AM Thread Starter
Hi Everyone.
I have a query on the IMA battery...
Is is normal for the battery to loose bars overnight for example; from 4 to 1 on the dash indicator?
DazGizmo is online now
post #2 of 22 (permalink) Old 02-27-2017, 10:48 AM
Originally Posted by DazGizmo View Post
Hi Everyone.
We would need to know more information.
How long did it sit?
What was the temp?
How often is this happening?
Age/Milage of car?
In general, no that is not normal. If it happened only once I would not worry to much as some times this will happen as the battery level is recalibrated. I have seen this once when my 2011 sat over night and most of the previous day in a very cold day (I think the high was like 2 degrees F).
DazGizmo likes this.
Eagle_f90 is offline
post #3 of 22 (permalink) Old 02-27-2017, 12:22 PM
I have had the meter drop one or two bars over night but the temperature went from like 60 degrees f to below freezing.
We would need more information and there was a software update for this kind of issue for some Model years. you may want to research and see if your year needed it and if it has been done.
Hi Everyone.
post #4 of 22 (permalink) Old 02-28-2017, 02:03 PM
I've not noticed anything like that since I had the "Battery Memory" re-program done. It was a recall campaign here in the US on I think 2011-2012...
Before that, it wasn't uncommon to see a 1 or 2 bar drop overnight.
96firephoenix is offline
post #5 of 22 (permalink) Old 02-28-2017, 02:44 PM Thread Starter
The bar drop overnight I think was a one off I think...
Spec
CR-Z GT 2011, 43500 miles, Temp 2 to 3 degrees Celsius
But the drive into work and then back home the battery seems to go into a discharge (eco mode). After 10-15 minutes driving when in traffic it gets to three bars then quickly goes to none in a few seconds. The engine then revs to about 1300-1400 rpm to force a charge into the IMA battery. Obviously the IMA stops working inc. Auto Stop until two bars are displayed... then it seems normal after this...
Is this normal behaviour?
post #6 of 22 (permalink) Old 02-28-2017, 02:59 PM
This does not sound normal for your model year. Check your manual but the IMA system should have a 8year 80k warrantee and if that is the case take it in to the dealer. Also make sure all updates have been done for the IMA system
post #7 of 22 (permalink) Old 02-28-2017, 03:08 PM Thread Starter
IMA Warranty - Not in the UK as we only have - 5 years or 90,000 miles, whichever comes first, for 11YM onwards Civic Hybrid, CR-Z, Insight and Jazz.
post #8 of 22 (permalink) Old 02-28-2017, 03:17 PM
Ok, I thought Honda did that world wide even though it was a US only requirement.
As far as I know the old NiMH batteries should not be dropping that fast and the computer was setup to prevent it from dropping below 2 bar. It sounds like there is something wrong.
post #9 of 22 (permalink) Old 02-28-2017, 03:26 PM
One word---------> Dealer
post #10 of 22 (permalink) Old 02-28-2017, 04:57 PM Thread Starter
Sounds like it could be normal... I do have the radio on and the heating on in Auto mode...
Found this and it similar/same as what is happening to me - Battery question
