Fastest Charging Method - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 07-14-2011, 11:05 PM   #1 (permalink)
Default Fastest Charging Method
I'm not sure if anyone has discovered this yet, but last week when I was getting ready to apply the brake I pressed it down lightly but not enough for the pads to begin touching the rotor. The CHRG meter went to full bars while I kept my foot lightly pressed on the pedal.
I have now been using this method to charge and slow the car down. Once I see a red light approaching I'll press the brake pedal only to activate the energy zapping that the IMA motor does to recharge, and once the red light is close I fully press the brake, so that the pads stop the car.
I've found that this charges the battery very fast, but it also activates the brake lights even though the pads aren't being used to slow the car just yet. I can hear the IMA battery fan blasting when I do this.
Viet is offline   Reply With Quote
Old 07-15-2011, 10:55 AM   #2 (permalink)
Scorch's Avatar
Yup this is what i've been doing too.
Scorch is offline   Reply With Quote
Old 07-15-2011, 08:50 PM   #3 (permalink)
InsightRacer's Avatar
It's a standard hyper-mileing trick based on the way the Honda IMA controls work. I used to do it on my 1st gen Insight.
It's great to do when you are comming to a stop, going down a steep hill or just want to slow down a ittle (because the Bozo in front of you drives like a old lady).
And if you want to charge but you aren't moving, put it in neutral and rev it to 3,000 RPM and hold it. It's a builtin charge feature.
Milano Red 6MT EX / Carbon Fiber storage lid / RCI Saftey Net / 205/45 Yokohama Advan Neova AD08s on 17x7 MB Weapons / JDP front lip and rear spoiler / Black Label Fab CAI & CAT Back / HKS Hiper Max III coilovers/ Engalls Fastcams (-2) / Hondata FlashPro Tuning / HKS Kansai Front Strut Tower Bar / Cusco Rear Strut Bar
InsightRacer is offline   Reply With Quote
