Fumoto Oil Valve? - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 06-30-2011, 09:27 PM   #1 (permalink)
BIO Hazard's Avatar
Default Fumoto Oil Valve?
I have a 2011 CR-Z. I want to score a Fumoto Oil Drain valve for my car.
I am being told that a F-106N is the part I need. Can anyone confirm that for me? Is there anything else I need to order at the same time? The Fumoto valve is not cheap so I want to get it right the first time.
Thanks in advance for your help!!!
BIO Hazard is offline   Reply With Quote
Old 06-30-2011, 10:45 PM   #2 (permalink)
Yes, you want the F-106 flavor and that will be the correct size.
The N at the end is optional. That will have a nipple on the drain end so that you can attach a small hose to direct the drainage. It's really not needed but if you want it, fine.
So you can order an F-106 or an F-106N. Either will work.
Old 06-30-2011, 11:56 PM   #3 (permalink)
JnC
JnC's Avatar
The only thing that I didn't care for about the valve is that it restricts the drain flow so much that it's.... very.... very.... slow.
2011 CR-Z EX, MT, no-navi, white
"Why are you chasing down the traffic light? It's not moving... I suspect you can creep up on it instead."
JnC is online now   Reply With Quote
