If possible, please post your dyno chart here along with supporting mods, and other information you have handy (type of dyno, gear of the run, transmission type, etc) Mods, can we also get this stickied?
T1R's baseline (stock)
Yellow line : stock Pink line: with no charge - Dyno is performed with Dynapak dynometer - Dynoed with 4th Gear - all numbers are SAE corrected ![]() again, with AJR / T1R exhaust - Dynoed with 4th Gear - Base line with stock vs T1R S51 Cat-back exhaust - all numbers are SAE corrected - tempurature 3 degrees celius ![]() taken from: T1R S51 Exhaust DYNO !!!
#4 (permalink) | |
Hondata CRZ / Temple of VTEC
-may be a pre production car -Has HKS exhaust ![]() Quote:
Here she is,
Dynoed today with the following mods -Black Label CAI -P2R Cat delete -KSK / P2R catback exhaust result (124whp / 117wtq) ![]() a little lower than i expected, was shooting for 130whp but either way it makes sense (hp makes sense, the tq number is lower than i expected). Runs were done back to back and in 4th. We didnt rev the car in neutral btwn runs to charge the battery up before doing it again so the numbers could end up a bit higher (when i was leaving I noticed the battery was at 1 bar). Also, didnt get to do a before dyno... EDIT: i dont recall if VSA was on or off during the runs either. This chart may not be the best dyno to use for comparison now that i think about it.
Whew, the torque curve is flat as a pancake at about 112 lb-ft. I'm impressed that someone finally noted 'wheel horsepower' and what gear the data was obtained in. I can't figure why the CR-Z stock is so slow. I guess the unconventional 4th gear dyno test is appropriate for the CR-Z, since the 6MT shifts out of 3rd gear shortly after 60 mph (sad), while cars such as the RSX-S reaches 60 mph at the top of 2nd gear, if I recall correctly. Good data.
#9 (permalink) | |
yeah, i think this thread could be really useful once more members get dynoed (especially when we start seeing boost). mods, sticky this thread!!
I have seen another handful of dyno charts here from members! If you've run your car post up so we all dont have to search for these things!
