Auto Stop-Start Wear & Tear - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 05-24-2011, 11:34 AM   #1 (permalink)
gordonfc's Avatar
Red face Auto Stop-Start Wear & Tear
Anybody have any idea regarding wear and tear on the starter system by shutting down and starting up 15 - 20 times a day (around town shopping etc)
I've been bypassing the shut-down by putting the front defroster on and fan set at 1 bar.
I know the systems been around for quite a while on other Honda's.
Any recalls on them, re the shut-down start-up system?
Old 05-24-2011, 12:34 PM   #2 (permalink)
TinTin's Avatar
the motor used to restart the car is also the one you use to assist the car while driving. If its ok to help move the vehicle, its going to be ok to start the engine since its a much less stressful task
Old 05-24-2011, 12:38 PM   #3 (permalink)
CRaZee's Avatar
It is designed to do that.. and Honda is really good when they design something. As mentioned, it is the IMA motor that starts the car... not going to hurt it! It is not like some cheesy, designed to fail starter you get on some cars.
Silver EX 6 Speed Navi
CRaZee is offline   Reply With Quote
Old 05-24-2011, 08:28 PM   #4 (permalink)
Autostart is fine. No worries. Is also in part why the prescribed oil is 0w20.. Unless your CR-Z is - eh - stretched as depicted in the avatar..
Old 05-25-2011, 12:09 AM   #5 (permalink)
I don't have a CRZ and don't really have the facts on the tear, but.
Potentially, the starting of the engine will stress out the mechanical parts like pistons, cam, crankshaft, connecting rod bearings, etc. This is because when the engine is shut off, the oil drains into the crank case. When it's restarted, for the first immediate time, the moving parts are running without the fresh supply of oil on them - until the oil pump bring the oil after a few moments. There must also be some relay that will eventually burn its contacts off due to so frequently engaging and routing such amount of current from the batteries to the electric motor.
Hopefully it will not happen before other major components on the car make it not worthy of a repair vs replacement (hopefully years from now).
Good question.
john21031 is offline   Reply With Quote
Old 05-25-2011, 12:19 AM   #6 (permalink)
kyo
It takes more than 30 seconds for the oil to 'drain off' the parts >_> ... if that was true, when you started any vehicle, especially older ones with sloppy tolerances and heavy weighted oil, you would hear grinding noises, ever hear metal on metal? it isn't pretty.
The car only uses a starter in EXTREME cold or depleted hybrid battery pack.
Relay burning out? Seriously, this isn't an car built in america ... /poke
If you really wanted to subscribe to this train of thought, then the ONLY engine you'd have in your car would be a rotary, surely you wouldn't want pistons that have to change directions 180 degrees 4 times per cycle compared to something that spins and carries its momentum through the combustion cycle. I mean, all that wear and tear on the rods and crank from a mass moving at insane speeds reversing direction at even greater speeds, how does it not just snap at 6000 rpm!!! That is TONS of force.
Engineering ... check it out sometime.
kyo is offline   Reply With Quote
Old 05-25-2011, 09:25 AM   #7 (permalink)
VTEC Mini's Avatar
The only thing I worry about is the inrush current. When ever you put the juice to any electrical device there is high spike of energy that hits it. That's why light bulbs blow out the minute you hit the switch. That might be a problem in the future.
http://www.crzforum.com/forum/image.php?type=sigpic&userid=409&dateline=13034976  56
VTEC Mini is offline   Reply With Quote
Old 05-25-2011, 12:06 PM   #8 (permalink)
RedefinedCRZ's Avatar
I honestly do not think you will ever see any issues with the IMA system. There are old Insights on the road with the original electric motors in them and batteries for that matter. I know the service department here in town said they just did a engine on one after 300,000 miles. The electric motor and batteries are still testing out strong, the gas motor is what went, and it was failure due to not replacing the timing belt at the right interval this last time.
Old 05-25-2011, 02:25 PM   #9 (permalink)
Originally Posted by RedefinedCRZ View Post
.it was failure due to not replacing the timing belt at the right interval this last time.
And here I thought you were going to say the engine failed due to all the autostopping!
Colin is offline   Reply With Quote
Old 05-25-2011, 04:20 PM   #10 (permalink)
The IMA doesn't use anything as crude as a relay - it's all solid-state switching. It has to be to control the amount of juice supplied, it's not simply an "on" or "off" thing. So no contacts to burn out and the current is controlled so inrush is kept in check too.
The comments about oil-drain have some validity and this may be one reason why auto-stop times out after 90 seconds.
2010 CR-Z GT 6MT
Crystal Black Pearl
lexicon is online now   Reply With Quote
