Any a/c pros? Prius 05 blowing hot air - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 03-01-2011, 08:05 PM   #1 (permalink)
hansolo's Avatar
Default Any a/c pros? Prius 05 blowing hot air
A few months back we had trouble with the a/c not blowing air at all but that was just due to the fan which I just unplugged and plugged back in and cleaned the filter. Now it's blowing like a champ but it's hot!
Is this something a recharge kit can fix? Or do I need new compressor? How can I check? Pressure tests? Dunno anything about A/Cs!
Thanks
Leia
11' CR-Z EX
hansolo is offline   Reply With Quote
Old 03-01-2011, 08:37 PM   #2 (permalink)
TinTin's Avatar
I dont know how much help you're going to get, this is a CRZ forum not a prius forum.
Old 03-01-2011, 09:50 PM   #3 (permalink)
hansolo's Avatar
well it is a car forum, basic knowledge with auto A/Cs is all i need lol
Leia
11' CR-Z EX
Old 03-02-2011, 11:45 PM   #4 (permalink)
blowing hot air? freon leak maybe? gonna cost u money!!!
2005 White Accord Hybrid
Hellionz is offline   Reply With Quote
Old 03-03-2011, 04:56 AM   #5 (permalink)
TCroly's Avatar
If your A/c is blowing hot and the compressor is engaging, which it may not be, you have a leak. It does no good to add freon Until you find the source of the leak.
As a result A/C problems like this are not DYI fixes. For example if you don't need freon and then add some you can destroy the compressor and other components from over charging your system with freon. You have to take it either to a shop that specializes in A/C fixes or the dealer to get it properly diagnosed. Don't be surprised if it is a really big expense to fix.
Old 03-03-2011, 05:12 PM   #6 (permalink)
hansolo's Avatar
blahhhhhhhh ok. thanks for info TCroly!
Leia
11' CR-Z EX
