The Element 166hp 161 ft-lb 3640 lbs 21.9277 lbs per hp The CR-Z 122hp 128 ft-lb 2637 lbs 21.61475 lbs per hp Just by power to weight ratio it should be a slight bit faster and obviously more nimble due to the lower weight. How does the additional low end torque from the electric motor factor in? I assume it would make it feel a little quicker. Finally is it true that the electric motor and batteries only store enough energy for like 3 ful throttle pulls? |
You can read my thread about running out of power when going up a hill, for the worst of it. That was driving w/ absolutely NO consideration for charging or anything. Taking the "sports" part of this sports/hybrid to its limits.
And I made a comment about 1/2 hour of fun driving and I was out of power, but w/out the long hill, I'd have gotten an hour of fun (no consideration for charging, floored whenever possible) driving for sure. I've never had a problem w/ normal driving around town. Then if you do start thinking about charging, that's just icing on the eco cake. It's the fastest car I've ever had, for where it matters.. Quick acceleration when you need it, during normal driving. I've never had fast cars, though. 2.0l hyundai elantra, mid 90's nissan maxima, mazda b-2000 pickup truck. Also the best handling car.. (heh, obviously) |
The automatic Element has a 10s 0-60 about the same as the CVT CR-Z. The 6MT CR-Z is at least as quick as 8.5s. And, it's got excellent low-end torque so for 0-30 it's even zippier than its 8.5s time.
It should be noticeably quicker and, as you say, quite a bit more nimble. |
#4 (permalink) | |
When I was first thinking about a crz the lack of power really turned me away, but when do some of us actually have the road or time to open up a car and use all that hp?
There are so many police/chp around here and with 25-40mph speed limits the crz is the perfect fit. Nice low end torque getting away from stoplights quicker than the minivan next to you...
#6 (permalink) | |
Its not underpowered for normal driving or even fun driving. The CVT is okay. I drove one first. My theory is that if the automatic is okay the manual will be better. The manual IMO is 2x better then the automatic.
I come from 340 horsies and my daily driver is an 8 cylinder boat beast. Its a lot of fun. Zip and Pep are the right words for this car. I sometimes miss my ponies, but its almost always on the big mountain stretches when I used to step down and do 100mph up them. Now I settle at 70.
2011 Honda CR-Z EX Black 6 Speed w/Navigation AKA "Spark" 2007 Yamaha FZ6 AKA "Mantis" |
98+% of the time you will not have a problem with IMA battery power. Where people get into trouble is driving in a straight line for miles and constant acceleration with no regenerative braking or deacceleration up to corners. If and when this happens to you, you can simply adjust your driving habits or style for this kind of driving route. I dont think this will be a problem.
As far as acceleration goes if your only requirement is that it as fast or faster than a Honda Element than you should like the CRZ just fine. With the IMA system 0-30 mph sprints will be much peppier. Your handling and nimbleness of the vehicle will be greatly improved over your Element.
2011 Honda CRZ, EX CVT Navi, Crystal Black Pearl ![]() 2010 Ford Escape 2009 Yamaha R1 2007 Ford Mustang GT/CS(Sold) |
