Changing light bulb in door..Help! - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 02-09-2012, 05:19 AM   #1 (permalink)
Default Changing light bulb in door..Help!
HELP!! This may sound dumb but I cant find an answer anywhere... I'm trying to change the bulbs to led. I got the dome light changed no problem but, when I removed the plastic cover to the side door lights, I can't figure out how to remove the bulb. I tried to just pull it, but since it didn't come out easily, I didn't want to keep pulling and risk breaking it... I tried turning it but it just lets the plastic part go into the door... sorry for the noob question. Thanks in advance!
smfs2h is offline   Reply With Quote
Old 02-09-2012, 05:37 AM   #2 (permalink)
sohcsol's Avatar
I believe they pull straight out... I taped over the door button so the light would stay off and not get hot.
If the socket falls inside the door you will have to pull the door panel off.
2011 CR-Z EX, 6MT, CBP, #7960
Old 02-09-2012, 12:51 PM   #3 (permalink)
They pull out. I remember a couple bulbs being a bit stubborn. Grip it firmly with your thumb and pointer finger and just pull straight back. Enjoy the LEDs!
Old 02-09-2012, 10:52 PM   #4 (permalink)
Awesome, I will try it again tonight! Thanks!!
Old 02-09-2012, 11:34 PM   #5 (permalink)
let us know if you got it.
Old 02-10-2012, 02:13 AM   #6 (permalink)
rk3
okey,,, how did you take the dome light cover off???
need help on that please..
rk3 is offline   Reply With Quote
Old 02-10-2012, 02:35 AM   #7 (permalink)
Kyleseghatch's Avatar
Small flat tip screw driver
<<<Anti-Fake Parts
CBP 6MT EX
My Build Thread
Old 02-10-2012, 02:37 AM   #8 (permalink)
Here is your DIY..
DIY - How to remove interior light covers and license plate lights (Bulb Replacement)
Old 02-10-2012, 04:45 AM   #9 (permalink)
rk3
thanks for the info...Aloha!
