This is my method to add two auxiliary composite video Inputs to a CR-Z that is equipped with the factory navigation system.
In other words, if you have a device that outputs video using one of these plugs, that image will appear on your Nav Screen.
Example of setup with Video Aux Input 1 (TV) and Video Aux Input 2 (Backup Camera)
The Disclaimers:
1) This is not an easy modification. You’ll need quite a bit of time and patience and there are many areas of potential errors and mishap. I am erring on the side of being more verbose than necessary – so if you hate reading then I suggest you find another DIY.
2) I am not responsible for damage that you may incur while attempting this DIY.
3) I am not responsible for how you ultimately use this DIY. All items are provided for educational purposes only.
4) Since you are dealing with electronics, you are increasing the fire-risk of your vehicle in the event of a short circuit or ignition created by the heat of added components.
5) This hack will effectively void the warranty on your factory Navigation screen (Nav).
6) My instructions are for the USA-spec CRZ. I am not sure what changes Honda implemented for homologation in other countries.
7) I recommend products from various vendors below. These are for guidance to explain the necessary component. I do not endorse or represent the retail seller or component manufacturers. The lone requirement for this DIY is the Navtool; the DIY will not be valid if you substitute another “piggyback” component that offers similar functionality.
8) I am not an electrical engineer by trade, so my approach may not be optimal for an installation. The following instructions are more for a proof of concept than for a long-term in-vehicle installation. That is, I use certain connector types to simply get things working, but you may want to consider using solder to fix wires and finding proper grounding points.
9) Yes, I realize it is cheaper to just buy your own aftermarket double-DIN and end up with a better result. This DIY is really for people who have the factory navigation and are exceptionally bored.
Overview:
The modification will piggyback a new piece of hardware that has the ability to override the image that is displayed on the OEM Honda navigation screen (Nav). This hack requires you to disassemble a portion of your Nav and physically modify it. There is no need to solder components, but your navigation system will be rendered useless if the piggyback hardware (Navtool) fails.
The Navtool has two RCA composite inputs that are activated in various ways. When finished, you will have two input options along with the ability to switch to the default factory navigation screen. One extra input will be triggered with a hard-wired switch on the dash. The other input will be activated when the CR-Z is in reverse.
Required Equipment:
Estimated total cost is $275 to $360 (depending on if you want to add a new AUX stereo audio input)
(1 unit) Navtool Hardware and harness: Part#NAVRGB / Part#HONDARIB
$180 to $220 incl shipping
Honda Civic NAV Video Converter Add DVD Back-Up Camera | eBay
You can use the “best offer” option – the amount the seller accepts seems to vary. I offered $180, but it seems other members on this site offered $170 to $200 (my $170 was not accepted).
(optional 1 Unit) PIE adaptor: HON03-AUX (audio-only)
NOTE: This is only useful if you wish to retain factory stereo audio AUX input for use with other devices
$85 shipped
Amazon.com: PIE HON03-Aux Honda/Acura Auxillary RCA Input Interface: Electronics
(1 unit) Round Rocker switch: 20mm or 13/16 inch mounting diameter (12v)
$5 shipped
SPDT Automotive Round Rocker Switch Black
At least 10 ft copper hookup wire:
$10 after tax
75-Ft. UL-Recognized Hookup Wire (20AWG) - RadioShack.com
(2 units) 4.8mm x 2.0mm female terminal connectors
$1 to $2 depending on lot size
TE CONNECTIVITY / AMP|9-0160481-1|TERMINAL, FEMALE DISCONNECT, 4 | Newark.com
(10 units) Twist on wire connectors
$5 to $10 depending on lot size
Amazon.com: IMPERIAL 71191 ROUND TWIST LOCK WIRE CONNECTOR 22-14 GA -BLUE PKG/100: Automotive
(1 unit) Mini Fuse Tap
$5 (approx) depending on vendor
Northern Auto Parts: - Pico ATM Mini Add A Circuit Fuse Holder Tap by PACIFIC IND. COMPONENTS, INC
(1 unit) pack of Mini Fuses
$10
30 Piece Self-Testing ATM Mini Blade Auto Fuse Set
Required tools:
some tools will be somewhat specialized – you may need to acquire some of them which may add to the installation cost
Screwdriver sets of various requirements:
. . . . . a) Small Phillips screwdriver set with 00, and 0 heads
. . . . . Amazon.com: Moody Tools 58-0670 6-Piece Slot/Phil/Screw Extractor Combo Reversible Driver Set: Industrial & Scientific
. . . . . b) Large slot screwdriver with long metal blade (to be used as a lever)
Ratchet set with 8mm and 10mm sockets
Unibit drill bit capable of creating 13/16 inch holes (or drill bit with 13/16 inch diameter). Or 20mm if you have metric tools… although metric is really expensive in the USA due to lack of demand.
Amazon.com: Irwin 10221 Unibit21 13/16-Inch to 1-3/8-Inch 1/2-Inch Shank Hole Enlarging Step Drill Bit: Home Improvement
OR Amazon.com: Unibit Metric Step Drills - unibit-21m 20mm to 34mmstep drill: Home Improvement
Wire Stripper & Crimp Tool (I am assuming you know how to use this; you may want to practice on various wires if you’ve never stripped copper wire before)
Amazon.com: Irwin Industrial Tools 2078317 7-Inch Multi Tool Stripper, Cutter and Crimper with ProTouch Grips: Home Improvement
Multimeter (a simple Voltmeter is sufficient). I am assuming you know how to use a multimeter... you may need to practice on some low-voltage electronics to learn how to read direct-current voltage.
Amazon.com: Equus 3320 Auto-Ranging Digital Multimeter: Automotive
Interior trim removal kit
http://www.amazon.com/Astro-Pneumat...ic-4505-5-Piece-Fastener/dp/B0017HX5DE/ref=sr_1_1?ie=UTF8&qid=1308634728&sr=8-1
Electric Drill with standard bits
Penetrating lubricant (Liquid wrench or WD-40… although I’m not a fan of WD-40)
Clean gloves
Masking tape
Electrical Tape
Flashlight
The “stereo unlock code” for your factory Honda head unit (car salesman should have presented this to you during purchase)
The Disclaimers:
Overview:
Required Equipment:
$85 shipped
$5 shipped
$10 after tax
$10
Required tools:
Clean gloves
Masking tape
Electrical Tape
Flashlight
