DIY - How to remove interior light covers and license plate lights (Bulb Replacement) - Page 19 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
post #181 of 190 (permalink) Old 01-19-2015, 06:13 PM
Anyone ever have any issues with the LED panel replacements not lighting up? The only 2 that aren't installed are the door lights. I think maybe the 194 bulb adapters are faulty. I've tried flipping the contact wires on the socket base and nothing.
Bird is offline
post #182 of 190 (permalink) Old 01-19-2015, 06:26 PM Thread Starter
CRaZee's Avatar
Assuming you tried other bulbs? I have seen some bad bulbs from some suppliers. Use a multimeter to check the current in the sockets? Try applying juice to the bulbs directly to test them?
Silver EX 6 Speed Navi
CRaZee is offline
post #183 of 190 (permalink) Old 01-19-2015, 07:11 PM
Yep. Tried another bulb to. I will fiddle with it again after work
Bird is offline
post #184 of 190 (permalink) Old 01-27-2015, 12:30 AM
badEXample's Avatar
Replaced my dome, door, cargo and LP lights with $15 set of T10 blue LEDs from Amazon.
Looks very cool. Great guide on cover removal, only difference was my '13 dome lights were same as others not the long ones with square led panel, though my set came with 3 of them, don't need em.
http://amzn.com/B005RGNW70
The OEM bulb pulls 0.22A.
The LEDs I DID use are 5-LED T10 type bulbs. Blue LEDs not yet measured, but some white LED bulbs the Amazon dealer sent to me (since I was short to replace all locations), come in at 36mA.
I think brightness speaks for itself. Not insanely bright, but definitely not dim.
The LEDs I DID NOT use (festoons with 8 LED on each bulb...dome lights???) are pulling 0.04A.
License Plate Comparison
Cargo LED comparison
Blue Cabin and Door LED's
badEXample is offline
post #185 of 190 (permalink) Old 06-13-2015, 11:15 PM
CRZ-FORUM HATER
Carzee's Avatar
Like the above post states, the 13+ model uses a 194 bulb for the map light. It cannot be oversized, must be the same length as the oem bulb or it will hit the cover.
However the hatch, rear cargo lights, doors, and backup lights all can accept oversize bulbs, there is plenty of extra room.
4th Annual CR-Z Dragon Meet
"My rear ending experience has been pretty pleasant"-Hondaholly
Carzee is offline
post #186 of 190 (permalink) Old 03-17-2016, 03:16 PM
JetG0ld's Avatar
So if i buy that Amazon kit for my 2016 will it fit?
JetG0ld is offline
post #187 of 190 (permalink) Old 03-18-2016, 03:26 AM
The interior light setup should be the same. I think the only model changes so far have been plastics- front bumper/grille (and fog lights), diffuser, and now the console.
If anyone knows I'm wrong, I'll edit out this post.
I cut down an LED "panel" to use for a cargo light, I think 48 surface mounts or something. When I open the hatch at night, it lights up my whole front yard.
post #188 of 190 (permalink) Old 03-18-2016, 10:25 AM
JetG0ld's Avatar
So in BadEx's post he said he needed some extra and also the dome light, so will that kit come with all the lights I need or do I need to seek out some extra ones? And in regards to the LED Panel, how exactly did you do that? I'd be interested to add it myself.
JetG0ld is offline
post #189 of 190 (permalink) Old 03-18-2016, 11:56 PM
Red&Black <3
HondaHolly's Avatar
You're so smart
2011 EX CVT
HondaHolly is online now
post #190 of 190 (permalink) Old 06-08-2016, 03:47 AM
I have a 2014 model, and with a little help from this guide, and 10 minutes, I replaced all the interior lights with blue leds. It looks awesome to me.
ID:	31337   Click image for larger version
Buzz_Kill is offline
