Went to the track - Page 4 - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Go Back   Honda CRZ Forum: Honda CR-Z Hybrid Car Forums > Honda CR-Z: General > CR-Z Motor Sports
Old 07-12-2011, 11:14 AM   #31 (permalink)
Originally Posted by lilfeat View Post
The stock Dunlops are run flat?
I did not see any mention of this in the manual or the Honda Web site.
Guess I need to look at the sidewall.
Or do you have larger optional wheels/tires package?
I thought they were, I thought I had read in the owners manual about them, maybe I am wrong, I will check the manual sometime, I could not find anything on the website. I have the base 16s. Either way, they suck, but I am not going to change them until they are dead.
muddy is offline   Reply With Quote
Old 07-12-2011, 11:17 AM   #32 (permalink)
lilfeat's Avatar
I agree that they are not too hot. Easy to get them to make funny noises with not too much lateral force.
Enjoy you day...
Lilfeat
2011 Storm Silver EX- CVT - NAV
lilfeat is offline   Reply With Quote
Old 07-12-2011, 11:51 AM   #33 (permalink)
Grip is relative, and I do not expect much grip from anything factory. My major qualm with them is how the car tends to sway on them as they roll over. I have wear about 1 inch up the side of the tire! When at the limit and on non-perfect surfaces, the car kind of floats on the tires and it can make the whole thing very unstable.
Old 07-13-2011, 08:59 AM   #34 (permalink)
Originally Posted by muddy View Post
Just remember, 40+ psi in the tires, traction control off, normal mode, and screw in the front tow point (and put a piece of tape through it to keep it from unscrewing.
Maybe leave trac on for the first few laps, after that, all it is going to do is overheat the brakes.
my stoptechs came in in time after all, so I didn't take it. I wouldn't want to do a whole weekend in it anyways, already had my wife's reluctant blessing to take her Z4 instead. I will try it for a session one day when its convenient though.
Momentum, Momentum Performance
Mike is offline   Reply With Quote
Old 07-19-2011, 08:33 AM   #35 (permalink)
cmbcrz's Avatar
That was a PDX with the SCCA. There is another one on August 6th, and I will be there instructing in the CR-Z.
WDCR Home
http://www.wdcr-scca.org/LinkClick.a...edownload=true This is a .pdf of the regulations for an event in the spring, they are the same August 8, but the dates have changed.
I only run with the SCCA for a number of reasons (professionalism, proper driver group placement, driver skill level, quality of training, quality of workers, and mostly safety), but there are other groups. The main two at Summit Point being Friday at the Track (FATT) and NASA. They all cost about the same. If you work as a flagger for 3 days at a PDX you get one driving day free!
They will place you in a group based on your experience, you can contact, the people to contact about that are in the .pdf. The advanced group does not have an instructor, the others do. Do not be surprised if they put you in a group lower than you expected if you do not have much car experience and only motorcycle. They sometimes start people a little lower at first to check them out.
Hope to see you out there!
Thanks muddy!!
cmbcrz is offline   Reply With Quote
Old 08-21-2011, 12:15 PM   #36 (permalink)
Agree with this comment - really can't stand stock tires.
Used to Eagle GTs on my Pontiac G6 (which is a boat compared to the Z and can take corners better right now).
I take the occasional turnaround a little too fast when in sport, and end up doing like a hop with stock tires. Bugs the **** out of me.
Widget is offline   Reply With Quote
