Feedbacks Wanted. Thanks in advance - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 11-04-2011, 02:59 AM   #1 (permalink)
Default Feedbacks Wanted. Thanks in advance
Carbonrevo is offline   Reply With Quote
Old 11-04-2011, 05:19 AM   #2 (permalink)
Ichii's Avatar
Isn't that the concept? I don't really like carbon fiber hood.
Ichii is offline   Reply With Quote
Old 11-04-2011, 05:37 AM   #3 (permalink)
Hi,
Thats right. Its only concept. not actual item. must find a good nice design.
Old 11-04-2011, 12:59 PM   #4 (permalink)
Varmint's Avatar
I gotta say "no" on that one.
The hood of the CR-Z is a wee bit bulbous. It would look better if the hood were lower/more sleek, but that's not in the cards. Gotta fit an engine under there and there has to be some extra room for a crush zone in the event of pedestrian impact.
To compensate for that high point, Honda designed the edges of the nose so that they climb up the A pillar just a bit. They also mounted the grille very low and far forward on the nose. You can see that even in the concept car.
These two design elements give the nose of the car the illusion of being longer than it really is. If it can't be low, making it appear long goes a long way toward giving it the sleek appearance they wanted.
Here's why I don't think your design will work. Adding cut-slats to the top surface of the hood does two things. The first is that it breaks up the long lines Honda built into the nose. The second is that it calls attention to the highest point on the hood. In short, those slats highlight the things that need to be covered up.
This is how your car works
Old 11-04-2011, 05:52 PM   #5 (permalink)
JCRZ's Avatar
If the cr-z came like varmints example, I would touch anything exterior wise. Anyways as for the hood, I say no.
Old 11-04-2011, 07:04 PM   #6 (permalink)
franck2725's Avatar
Send a message via MSN to franck2725
09 concept car with hood photoshoped...not really
No
franck2725 is offline   Reply With Quote
Old 11-04-2011, 08:59 PM   #7 (permalink)
CR-Z Canadian's Avatar
Not to mention that the concept hood design would require cutting the top of the front bumper, wouldn't it?
You could cut it back, but then you break up the lines even more, and as Varmint said, the illusion of a long nose gets totally lost.
Old 11-04-2011, 09:05 PM   #8 (permalink)
Thanks Guys. Your feedbacks are very much appreciated. Very good feedbacks from here. Thanks Alot!
Old 11-04-2011, 09:51 PM   #9 (permalink)
bansky's Avatar
barf !
2011 HONDA CRZ EX CVT CBP (STOCK ... FOR NOW !)
bansky is offline   Reply With Quote
Old 11-05-2011, 01:37 AM   #10 (permalink)
Originally Posted by bansky View Post
barf !
Hi,
What is barf?
