How to wire a switch with an inline fuse - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 11-02-2011, 07:17 PM   #1 (permalink)
Default How to wire a switch with an inline fuse
With a three pronged switch that I plan to use on some led's, I am confused on where the fuse would go. Power from the battery comes in to the switch to one prong, while another prong goes to ground. The third prong is the load one which supplies the led's with power when turned on. The led's will also be grounded. My question is, if I am wiring an inline fuse, does it go inbetween the battery and the switch or inbetween the switch and the led's?
Also, is a 1 amp fuse sufficient for an led strip?
sandwich14 is online now   Reply With Quote
Old 11-02-2011, 07:24 PM   #2 (permalink)
Before the switch, closest to the battery. As for a 1 amp fuse, I suppose it would depend on the length of the strip and the numbers of LEDs on it.
Lankysean is online now   Reply With Quote
Old 11-02-2011, 08:15 PM   #3 (permalink)
I agree with that. That way, you minimize the length of unprotected wire that can possibly short to ground. Now, remember that fuses and circuit breakers' primary purpose is to protect the wiring, not your lights. So, what fuse you choose ultimately depends on what size wiring you decide to use.
On that note, I recommend 20 AWG or larger. Anything thinner than that is not recommended because the wiring may break from being vibrated.
My recommendation: 2.5-amp fuse with 20 AWG wiring.
cyeung is online now   Reply With Quote
Old 11-02-2011, 10:37 PM   #4 (permalink)
Thanks for the replies. I was going with 18 gauge wire, but can change it to 20 gauge if needed. Also the LED strip is 36 inches long with 36 led's total. Is 2.5 amps still sufficient?
Old 11-02-2011, 10:43 PM   #5 (permalink)
18 gauge is larger then 20, gauges are weird that way. As for the fuse, I'm not sure but I ran WAY more then that on a 5amp in my last car.... something like 300 LEDs, so yeah I'd assume it is fine.
