I had the P2R downpipe installed a couple days after I put in my cat back HKS exhaust which I installed a couple days after the HKS intake. The HKS exhaust is fairly quiet, it's just a little deeper than the oem exhaust, which I love. When I put on the downpipe it makes you notice the exhaust a lot more, but in a good way. I'm not a fan of big loud exhausts but the combo between the 2 let's others know there's something there without being obnoxious. Really quiet at idle and a little louder when stepping on it. Power gains aren't too crazy. You can feel the throttle is a lot more responsive and the car pulls a little more but that's it. MPG's are actually better as long as you're not on it all the time trying to feel the little bit more power.
Since it sits directly below you, the cat delete down pipe increases the cabin noise a bit.. no noticable change with the resonator/muffler and would assume the same with any aftermarket mid/catback system.. Not going to change the external sound significantly..
#4 (permalink) | |
you hear the backfire / burble of any exhaust much more with a cat delete installed.
this is my experience from 3 exhausts and 2 cat deletes - the sound is much more aggressive and it does get louder outside of the car for sure.
