Hondata Flashpro - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
Old 08-15-2011, 01:29 PM   #1 (permalink)
carlg1212's Avatar
Default Hondata Flashpro
I saw this on CorSport's site: CorSport: Honda - 2006-2011 Honda Civic Si - FP-SI-US
Does anyone know if they have this available for the CR-Z? I understand you can adjust gear ratios with Civic version...looking to get a little shorter gear ratios on the CR-Z 6MT.
carlg1212 is offline   Reply With Quote
Old 08-15-2011, 02:51 PM   #2 (permalink)
code85's Avatar
can't use it unless you have your ecu reflashed by Hondata. That service isn't available from them yet.
code85 is online now   Reply With Quote
Old 08-15-2011, 03:20 PM   #3 (permalink)
also, a flasher won't change your actual gears, it will only change how the computer interprets your gears for speedometer purposes. you want new gears, you need a new tranny.
Old 08-15-2011, 03:58 PM   #4 (permalink)
not to mention hondata doesn't answer emails
Old 08-15-2011, 09:17 PM   #5 (permalink)
TinTin's Avatar
I bet the flash pro increases downforce too...
Old 08-15-2011, 09:19 PM   #6 (permalink)
you have to get the hondata with a wireless plan if you want to email with it
Old 08-15-2011, 09:32 PM   #7 (permalink)
I talked to Hondata about this a couple of months back; they said that it is a year or two away.
With the low numbers of CRZ's sold (low demand, low number of beta testers available), and the fact that decoding/rewriting takes time...anything from Hondata is at least 18 to 24 months away.
Stealth is offline   Reply With Quote
Old 08-15-2011, 09:37 PM   #8 (permalink)
TinTin's Avatar
i also hear that flash pros can reduce overall weight by 200 kilos.
Old 08-15-2011, 09:39 PM   #9 (permalink)
TinTin's Avatar
some say that a flashpro will give your car autopilot.
Old 08-15-2011, 09:39 PM   #10 (permalink)
TinTin's Avatar
flashpros also allow your vehicle to hold more fuel for long trips.
