i have festoon now. this one has double sided tape on the back. i could have sworn the T1R kit had LED panels. i was thinking of breaking the side pieces of plastic inside the housing, but i assume those cause the light to spring back when you press it, so maybe not.
#7 (permalink) | |
$12.99 ![]() This panel has 12-SMD 1210 chips and is small enough to fit in most spots. It measures 1.25" in length and 0.78" in width. It includes 3M double sided tape as well. This is a nice upgrade if you want a soft and subtle interior light, but if you want maximum brightness, go with our 6-SMD D31 Festoon bulbs.
info@ijdmtoy.com / ADD US ON FACEBOOK! Monday - Friday 9AM-6PM PST LED & HID Automotive Lighting Experts. LED Bulbs, HID Conversion Kit, Daytime Running Lights |
i was using the 6-smd's but found them not bright enough. i would have assumed the 12-smd are brighter since there is twice as many LEDs. is your 12-smd kit $13 for the pair? that seems like a good price. also, why would the 6-smd be more bright?
#9 (permalink) | |
The 6-SMD Festoon bulbs are a bit brighter due to the type of LED chip used vs the 12-SMD Festoon. The 6-SMD bulbs use 5050 LED chips which are larger chips which produce more output than the 12-SMD bulbs which use 1210 LED chips. The 1210 LED chips provide about 30-45 lumens of output and the 5050 LED chips provide about 80-100 lumens. Hope that helps.
